Bandit Remove/Add - Printable Version +- MYSTRAN Forum (https://www.mystran.com/forums) +-- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=4) +--- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=5) +--- Thread: Bandit Remove/Add (/showthread.php?tid=30) |
Bandit Remove/Add - Admin - 05-13-2020 EDIT: BANDIT has been restored in Version 11.0 BANDIT is desired (although not mandatory) if we continue to have a "banded" solver. Although the LAPACK routines, which are optimized for banded matrices, will work on matrices that are not banded, it could result in excessive solution times. Once we get a sparse solver the only use of the banded solver will be as a backup in case the sparse solver fails. Starting with 10.3, we decided to depreciate BANDIT because it was causing compiling errors. It can be added back later once those errors are resolved. To add BANDIT back in, download the following ZIP file: https://www.mystran.com/docs/BANDIT.zip |
