Compile 10.31 with Code::Blocks - Printable Version +- MYSTRAN Forum (https://www.mystran.com/forums) +-- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=4) +--- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=5) +--- Thread: Compile 10.31 with Code::Blocks (/showthread.php?tid=33) |
Compile 10.31 with Code::Blocks - Admin - 05-17-2020 EDIT: See this thread for the most current: https://www.mystran.com/forums/showthread.php?tid=2 I will create detailed instructions later, but for now, this is one option that seems to be very close. 1. You can use Code::Blocks in the same way as Visual Studio. I also tried CBFortran, but it seems to be 32-bit and was much slower when reading in the source files. http://www.codeblocks.org/downloads/26 Download "codeblocks-20.03mingw-setup.exe". This will add the Fortran compilers in the CodeBlocks install directory. 2. Download this modified 10.31 source code, which has some minor modifications from 10.31. https://www.mystran.com/misc/Source.zip For reference, here are the modifications that were made (you don't need to do this if you download from the above link) - Delete the BANDIT directory - In GET_COMMAND_LINE.f90, comment out INTRINSIC GETCL in line 46 - In GET_COMMAND_LINE.f90, change "CALL GETCL ( FILNAM )" to "CALL GET_COMMAND_ARGUMENT ( 1, FILNAM )" - In MYSTRAN.f90, line 128, change OPEN(SC1,CARRIAGECONTROL='FORTRAN') to OPEN(SC1) - In MYSTRAN.f90, for the line that says : "PERCENT_CHANGE(LOAD_ISTEP,NL_ITER_NUM) = 1.0D2*(UG_NORM(LOAD_ISTEP,NL_ITER_NUM) - UG_NORM(LOAD_ISTEP,NL_ITER_NUM-1)) &" delete a space before the "&" character. 3. - In Code::Blocks, start a new project. You don't need to select a compiler now. - Under settings/compiler/Toolchain Executables, click the GNU Fortran Compiler and point to this directory, C:\Program Files\CodeBlocks\MinGW. Then, replace the first 3 EXE files with with gfortran.exe (or the 64 bit MinGW) - Right click the project name in the tree and add all 10.31 directory recursively. You may also want to put the in a directory that has a short and simple path. In my case this took about 10 min so you may need to be patient. - In Project/Build Options/Search Directories, select the INCLUDE directory location under both "Compiler" and "Linker" tabs. Also, check both the Debug and Release tabs. Otherwise, it will not find debug.h and stat.h - Build/Rebuild ISSUE: At this point, Intel would normally compile, but I am not having success. At the end is says "Execution of 'X.. failed", where X is the compiler (Execution of 'mingw32-gfortran.exe...or Exectution of 'gfortran.exe..., etc). A google search has not helped to resolve it. Upon closing CodeBlocks and then reopening it, I get a different error related to Pentium-II. That seems to be resolved by just clicking Settings/Compiler/Toolchain Executables and selecting the GNU Fortran compiler. But this is odd behavior! For reference, here is the Makefile associated with this attempt. I changed the path to C:\A instead of C:\Source though in an attempt to shorten fix it (though that did not work). https://www.mystran.com/misc/Makefile And here is the build log for reference. https://www.mystran.com/misc/M5_build_log.html |
