OLD - CURRENT AND ARCHIVE VERSIONS - Printable Version +- MYSTRAN Forum (https://www.mystran.com/forums) +-- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=4) +--- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=5) +--- Thread: OLD - CURRENT AND ARCHIVE VERSIONS (/showthread.php?tid=39) |
OLD - CURRENT AND ARCHIVE VERSIONS - Admin - 06-24-2020 This thread is considered to be outdated, but is kept for reference. For the most current and archive versions, see: https://www.mystran.com/forums/showthread.php?tid=83 ---OUTDATED THREAD FOLLOWS--- LAST EDIT: 11/11/2021 For end users, the following links are for the most current official version: Version 13.3 Windows EXE - https://www.mystran.com/versions/MYSTRAN_13.3A.zip - Compiled by Bill Case Windows EXE - https://www.mystran.com/versions/MYSTRAN_13.3B.zip - Compiled by TBD Linux - See the procedure on GitHub: https://github.com/dr-bill-c/MYSTRAN Documentation (NEEDS UPDATE) - https://www.mystran.com/documentation/MYSTRAN_Docs_1_29_2021.zip Benchmark Runs and Process - https://www.mystran.com/versions/Benchmark_11_29_2021.7z Notable Modifications from the prior official version: -TBD Additional files not commonly used by end users: Source Code (in Zip Form as opposed to GitHub form - direct download) - https://www.mystran.com/versions/MYSTRAN_13.3_Source.zip Test Problem Hand Calculations (60MB) - www.mystran.com/documentation/MYSTRAN_Test_Problem_Hand_Calculations.pdf ------------------------------------------------------------------------------------------------------------------- NOTE: The most current source code for developers is on GitHub ( https://www.mystran.com/forums/showthread.php?tid=2 ). RE: Current and Archive Versions - Admin - 06-25-2020 OLDER VERSIONS --------------------- Version 12.1 Windows EXE - https://www.mystran.com/versions/MYSTRAN_12.1A.zip - Compiled with Option 1 (Preferred) by Bruno Windows EXE - https://www.mystran.com/versions/MYSTRAN_12.1X.zip - Compiled by Bill - Unknown process (perhaps via Lahey Fortran) Linux - See the preferred option in this thread: https://www.mystran.com/forums/showthread.php?tid=2 Documentation - https://www.mystran.com/documentation/MYSTRAN_Docs_1_29_2021.zip Test Runs (used to benchmark and may also be used as reference DAT/BDF files) - https://www.mystran.com/versions/MYSTRAN_12.1_TestRuns.zip Notable Modifications from the prior official version: - Corrected error for the BUSH element and other more minor changes. - Introduced the new MYSTRAN Benchmark Tool in the Test Runs ZIP Additional files not commonly used by end users: Source Code (in Zip Form as opposed to GitHub form - direct download) - https://www.mystran.com/versions/MYSTRAN_12.1_Source.zip Test Problem Hand Calculations (60MB) - www.mystran.com/documentation/MYSTRAN_Test_Problem_Hand_Calculations.pdf Version 12.0 Windows EXE - https://www.mystran.com/versions/MYSTRAN_12.0A.zip - Compiled with Option 1 (Preferred) Windows EXE - https://www.mystran.com/versions/MYSTRAN_12.0B.zip - Compiled with Option 2 (Alternate) from the compile thread using CodeBlocks and gFortran (10.2.0 x64) and SuperLU version 5.2.2 Linux - See the preferred option in this thread: https://www.mystran.com/forums/showthread.php?tid=2 Documentation - https://www.mystran.com/documentation/MYSTRAN_Docs_1_29_2021.zip Test Runs (used to benchmark) - https://www.mystran.com/versions/MYSTRAN_12.0_TestRuns.zip - Note that starting with 12.0, the Test Runs have been updated to be in sync with gFortran Notable Modifications from the prior official version: - Added the SuperLU sparse solver. Previously there was only an option to use the LAPACK banded solver. The sparse solver is more efficient and necessary for problems with a larger number of DOF. RE: CURRENT AND ARCHIVE VERSIONS - Admin - 12-04-2020 Note that before version 11.0, the compiling process was to use the Lahey compiler and Perl scripts. Also, the source code, manuals, and test run are grouped in the Package. Version 11.2 Windows EXE - https://www.mystran.com/versions/MYSTRAN_11.2.zip - 8/30/2020 Linux - See Option 2a in this thread: https://www.mystran.com/forums/showthread.php?tid=2 Documentation - https://www.mystran.com/documentation/MYSTRAN_Docs_9_13_2020.zip Test Runs - https://www.mystran.com/versions/MYSTRAN_11.0_TestRuns.zip Notable Modifications from prior official version: - Added files needed to incorporate a sparse solver. These were previously removed when the Intel sparse solver was removed. - Added msg/error in the event that a CQUAD4 with orthotropic properties is used. The current CQUAD4 has an issue with this scenario: https://www.mystran.com/forums/showthread.php?tid=46&page=3 Additional files not commonly used by end users: Source Code (in Zip Form as opposed to GitHub form - direct download) - https://www.mystran.com/versions/MYSTRAN_11.2_Source.zip Version 11.1 Windows EXE - https://www.mystran.com/versions/MYSTRAN_11.1.zip Documentation - https://www.mystran.com/documentation/MYSTRAN_Docs_7_12_2020.zip Test Runs - https://www.mystran.com/versions/MYSTRAN_11.0_TestRuns.zip Source Code - https://www.mystran.com/versions/MYSTRAN_11.1_Source.zip Version 11.0 Windows EXE - https://www.mystran.com/versions/MYSTRAN_11.0.zip Documentation - https://www.mystran.com/documentation/MYSTRAN_Docs_7_12_2020.zip Test Runs - https://www.mystran.com/versions/MYSTRAN_11.0_TestRuns.zip Source Code - https://www.mystran.com/versions/MYSTRAN_11.0_Source.zip Version 10.31 Package - https://www.mystran.com/versions/MYSTRAN-FEA-Program-ver-10.31.zip Windows EXE - https://www.mystran.com/versions/MYSTRAN_10.31.zip Version 10.3 Package - https://www.mystran.com/versions/MYSTRAN-FEA-Program-ver-10.3.zip Windows EXE - Not currently available Version 10.2 Package - https://www.mystran.com/versions/MYSTRAN-FEA-Program-ver-10.2.zip Windows EXE - https://www.mystran.com/versions/MYSTRAN_10.2.zip Version 10.0 Package - https://www.mystran.com/versions/MYSTRAN-FEA-Program-ver-10.0.zip Windows EXE - Not currently available Version 9.03 Package - https://www.mystran.com/versions/MYSTRAN-FEA-Program-ver-9.03.zip Windows EXE - https://www.mystran.com/versions/MYSTRAN_9.03.zip RE: CURRENT AND ARCHIVE VERSIONS - Admin - 02-04-2021 . |
