NASTRAN-95 vs MYSTRAN - Printable Version +- MYSTRAN Forum (https://www.mystran.com/forums) +-- Forum: ComLab and NASTRAN-95 (https://www.mystran.com/forums/forumdisplay.php?fid=10) +--- Forum: ComLab and NASTRAN-95 (https://www.mystran.com/forums/forumdisplay.php?fid=11) +--- Thread: NASTRAN-95 vs MYSTRAN (/showthread.php?tid=4) Pages:
1
2
NASTRAN-95 vs MYSTRAN - Admin - 01-11-2020 It is relevant to compare MYSTRAN to NASTRAN-95 and also discuss the state of NASTRAN-95. ----------------------------------------------------- NASTRAN-95 (Advantages): - More developed and includes aero and fluid elements. - More history of use (more well known) - The buckling solutions are more developed (MYSTRAN only supports beam elements for Eigen solutions). - DMAP capability NASTRAN-95 (Disadvantages): - The user manual may need updates. - Some of the element formulations are old (i.e. shells may exhibit shear locking). - The code may be difficult to develop, but there may be a few developers who can work with it. - The solver that is used may be outdated by today's standards (considering the solver is at least 25 years old). - No PSHELL or PCOMP? NASTRAN-95 (Unknowns): - There appears to be some nonlinear analysis capability, but the extent is not known. Need to investigate the MATS1. ----------------------------------------------------- MYSTRAN (Usability) - A compiled version for Windows exists. - Complete processes for compiling in Windows using open source tools. MYSTRAN (Advantages) - Perhaps the biggest advantage of MYSTRAN is developers should find it more user friendly. - Created with more modern software and hardware in mind. - User manual is complete and updated. - Newer solvers can be incorporated with relative ease. MYSTRAN (Disadvantages) - Not as developed (less features) or well known as NASTRAN Extra info on - borges - 08-13-2020 Based on my previous work with NASTRAN-95, I'd like to bring forward some information you might find useful in some way to keep this comparison correct and up-to-date. Regarding NASTRAN-95's capabilities:
RE: NASTRAN-95 vs MYSTRAN - Admin - 08-13-2020 Wow, that is great information. I am not sure how you feel about NASTRAN-95, but it seems like a lot of work and it doesn't seem to be able to attract attention from developers (steep learning curve). Harry Schaeffer does have a version called ComLab for $100 ( https://github.com/nasa/NASTRAN-95/issues/5 ). But he is very familiar with the NASTRAN and I think it was a significant effort (and not open source). Some months ago, I talked to someone else who wanted to get serious about NASTRAN-95, but it fizzled out when reality hit. RE: NASTRAN-95 vs MYSTRAN - ceanwang - 08-15-2020 “NASTRAN-95 cannot allocate more than 14 million words (56 MB) to its open core. Any value of OCMEM above 14000000 will cause a fatal error to be issued. That makes it unable to load larger models, and limits the in-memory database size for medium-sized models, therefore hurting performance.” NASTRAN-95 may not has open core more than 14m, but it was designed to solve big case with small machine. It solves, but not in high performance. Especially not fully use today hardware's capacity. RE: NASTRAN-95 vs MYSTRAN - borges - 08-15-2020 (08-15-2020, 02:11 PM)ceanwang Wrote: NASTRAN-95 may not has open core more than 14m, but it was designed to solve big case with small machine. It solves, but not in high performance. Especially not fully use today hardware's capacity. Well, as long as NASTRAN-95 can load the model (such as by setting low values for DBMEM, hurting performance), it'll sure solve it. But that was not my point. I was talking about how the 14 Mword (56 MB) OCMEM limit creates an upper limit for loadable model size (as in nº of elements). There are several "model checking" subroutines (e.g. CIDCK) that that are run before other pre-solve steps (e.g. BANDIT) and they do operations which require allocating memory (e.g. some kinds of sorting). Since for some of these subroutines the amount of required memory grows monotonically with respect to how many of a card you have in the bulk data block, there is an upper limit to how many of that card you can have. And since that happens for rather common cards (e.g. GRID), the memory upper bound creates a model scale upper limit. In practice, this means there are models used today that cannot, by any means, be run by NASTRAN-95, because the memory required for running basic pre-solving subroutines on them exceeds the upper bound on open core memory. In order to run them, you must either edit the model (make it coarser?) or change NASTRAN's code so either the involved subroutines use up less memory or there's more memory to begin with. RE: NASTRAN-95 vs MYSTRAN - Admin - 08-15-2020 Speaking of solving, one of other issues with NASTRAN-95 is that I believe it has a very old sparse solver. We removed the old Intel sparse solver from MYSTRAN because it was not robust (it still has LAPACK banded solver though). But it would be really good to add the PaStiX sparse solve to MYSTRAN. I will try to get more information about that. CalculiX recently added it and I think it is a really good option. RE: NASTRAN-95 vs MYSTRAN - ceanwang - 08-15-2020 (08-15-2020, 07:02 PM)borges Wrote: I was talking about how the 14 Mword (56 MB) OCMEM limit creates an upper limit for loadable model size (as in nº of elements). You buy a 4g ram PC, you can load some models. When you want to load bigger model, maybe you need to open the PC to expand the ram to 8g. It is the same as the OCMEM. You need to edit the program to increase it. RE: NASTRAN-95 vs MYSTRAN - borges - 08-16-2020 (08-15-2020, 11:29 PM)ceanwang Wrote: You buy a 4g ram PC, you can load some models. When you want to load bigger model, maybe you need to open the PC to expand the ram to 8g. It doesn't matter how many RAM your PC has. Mine has about 16 GB. However, none of that matters: OCMEM is an environment variable that you pass to the NASTRAN-95 executable to tell it how many (four-byte) words it should attempt to allocate for its open core. You can set it to any positive integer value equal to or less than 14000000, representing 56 MB of open core. Setting it to any value outside of that set (e.g. "14000001", "-5", "2.71828", "donuts"), regardless of file validity or model scale, will cause a fatal message to be issued: Code: LARGEST VALUE FOR OPEN CORE ALLOWED IS: 14000000That's the entirety of an .f06 file I just produced by calling NASTRAN-95 with a good model while having set OCMEM=14000001. No matter how much memory your PC has, NASTRAN-95 will never allocate more than 56 MB for its open core, thus creating an upper bound on loadable model size. Furthermore, even if you changed the code to let NASTRAN-95 use all of its open core address space (like IBM did), you'd still be limited by the fact it most likely uses 32-bit integers to address the open core, so even then you'd be limited to around 2 (or 4 if unsigned) GB, which is nice, but way below large production-scale models in use with modern NASTRANs such as Simcenter's. RE: NASTRAN-95 vs MYSTRAN - ceanwang - 08-17-2020 (08-16-2020, 01:12 AM)borges Wrote: However, none of that matters: OCMEM is an environment variable that you pass to the NASTRAN-95 executable to tell it how many (four-byte) words it should attempt to allocate for its open core. You can set it to any positive integer value equal to or less than 14000000, representing 56 MB of open core. Setting it to any value outside of that set (e.g. "14000001", "-5", "2.71828", "donuts"), regardless of file validity or model scale, will cause a fatal message to be issued. The program set the largest number at 14000000, you ask more than that, sure you will get a warring. You need to raise that largest number in the program. RE: NASTRAN-95 vs MYSTRAN - borges - 08-17-2020 (08-17-2020, 02:28 AM)ceanwang Wrote: The program set the largest number at 14000000, you ask more than that, sure you will get a warring. I'm somewhat skeptical of the meaning of "just change the max value" -- they must've set it at 14 M for some reason. Keep in mind the doc where they claim to have gotten it to alloc 2 GB also mentions it having been "a lot of work". But even if you DID change the max value and that didn't break NASTRAN-95's memory management strategy outright (which I find unlikely), you'd still be limited to 2-4 GB max, which is still not enough for commercial-scale models. Keep in mind those models require more than twice that to even pass the checks, and are often alloc'd several dozens of gigabytes' worth of in-memory database in order to run in reasonable amounts of time. All in all, rewriting the memory management code seems like so much of a hassle... It pretty much sums up how I feel about NASTRAN-95 as a whole: it's an outdated program; it can't run models output from modern CAD software, and even after converting unsupported elements (lossily so), it still has hard limitations on scale, run time, and output quality. It's good, in the name of science, legacy and all that, that we got it to compile and run on modern machines, but we shouldn't put any effort into trying to improve it. Well, I certainly won't. We should keep good docs on this amazing piece of legacy software, let it inspire us when possible, but focus actual work on more modern OSS solutions like MYSTRAN. |
