CQUAD4 in bending test - Printable Version +- MYSTRAN Forum (https://www.mystran.com/forums) +-- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=4) +--- Forum: MYSTRAN (https://www.mystran.com/forums/forumdisplay.php?fid=5) +--- Thread: CQUAD4 in bending test (/showthread.php?tid=46) |
CQUAD4 in bending test - O_Stodieck - 08-27-2020 Hi, I am getting some unexpected results running the attached cantilevered composite plate model in Mystran 11.0. :
Do you have a simple test case for shell (CQUAD4) element bending that I can run to test the installation? Thanks. RE: CQUAD4 in bending test - Admin - 08-27-2020 Can you check the reaction forces to make sure you are applying the correct load? There is a 0.1 scaling factor in the FORCE card so you may want to double check that. Have you tried an isotropic material to see if the results are correct for that first? I will let Bill know as well. RE: CQUAD4 in bending test - drbillc - 08-27-2020 I'll take a look at it and get back to you RE: CQUAD4 in bending test - O_Stodieck - 08-27-2020 (08-27-2020, 06:26 PM)Admin Wrote: Can you check the reaction forces to make sure you are applying the correct load? There is a 0.1 scaling factor in the FORCE card so you may want to double check that. Have you tried an isotropic material to see if the results are correct for that first? I will let Bill know as well. Reaction forces are correct - factor of 0.1 is intended. The element node numbering is such that the vectors from grids 1 to 2 point in the x-direction for all elements - this is matched in the comparison models - so I don't think this is an input error? Besides, the results are not any closer if the plies are set to 90deg in the PCOMP cards. As you suggested, I reran the model using an isotropic material - results are much closer (<2% error). Comparing Zmax in the T3 deflection at grid 737: Analytical (Bernoulli beam): I = (1.25e-04*12)**3*0.15/12 = 4.21875e-11 F = 0.1 L = 1.5 E = 70.0E9 Zmax = F*L**3/(3*E*I) = 0.038095 Mystran (see file attached) Zmax = 3.762719E-02 RE: CQUAD4 in bending test - drbillc - 08-27-2020 I just did a quick calculation treating the plate as a beam (should be good assumption since the aspect ratio is 20 to 1) and get a displacement at the end that is within 7% of the MYSTRAN plate problem result. I did run the problem in MYSTRAN and get exactly what you got, the displacement of 0.03613558. See the attached jpg which shows the beam displacement within 7% of the plate solution. Can you tell me what other sources gave you such a different answer? RE: CQUAD4 in bending test - Admin - 08-28-2020 O_Stodieck, can you show your hand calculations for the original problem as well? The composite version. RE: CQUAD4 in bending test - drbillc - 08-28-2020 Sorry, I used the wrong width (.075 rather than .15). But where did the 70E+09 for modulus come from? RE: CQUAD4 in bending test - Admin - 08-28-2020 (08-28-2020, 12:05 AM)drbillc Wrote: Sorry, I used the wrong width (.075 rather than .15). But where did the 70E+09 for modulus come from? Bill, there are two decks in the different posts and it was changed between them. Its a bit confusing, but maybe it was an attempt to try to make the composite more "isotropic-like". Not sure. RE: CQUAD4 in bending test - drbillc - 08-28-2020 O_Stodieck, I was looking for a good QUAD4 example to send you and, in the process, uncovered an error in MYSTRAN that crept in between versions 10.1 and 11. It is a plate problem with a pressure load that has a theoretical solution so that you can see how well MYSTRAN gets that answer. I will fix the error and then send you the bdf, but in the meantime MYSTRAN may crash with a shell pressure load. RE: CQUAD4 in bending test - O_Stodieck - 08-28-2020 (08-28-2020, 12:02 AM)Admin Wrote: O_Stodieck, can you show your hand calculations for the original problem as well? The composite version. Sure - I have posted a python implementation of the CLT approach here https://gist.github.com/ostodieck/d0411f789b35f51e9836412db4ccf512 I hope this is self-explanatory enough - let me know if something is unclear. The laminate and materials are the same as in the first post, and the tip deflection is 0.29625 m as expected. Thanks for checking this! |
